1994 Sunbird LE 2.0L manual.
The original reason this car sat for 4 years was this same problem.
What befuddles me is once the car has been started it restarts quickly.
like as if it was reminded oh yea! I'm a car and am supposed to run!
The symptoms are as you crank the engine it tries to start. The revs pick up and it sputters if you stop key. Visualize saying C'mon baby as you crank it.
Does this about 3 times before it starts.
I have replaced the fuel pump. Also turned key on and off to try build up fuel pressure. No help. Right now it is starting. Just need to troubleshoot further.
Its my recollection that the fuel pump produces 50psi to overcome injectors, then has a regulator that drops pressure to 7 or 8 psi for run pressure via vacuum operated regulator. would that regulator cause the fuel not to be getting to the rail before starting? Sounds like its starving for fuel
