i purchased this funnel called ez funnel ,, what you do is hook this funnel up to your rad , you fill the rad up all the way leaving fluid in the ez funnel .. then turn the fan in the van to off .. and the heat to max , then you hold throttle under hood , so your vans idling around 2000 rpm , . i do this while parked on a slight hill so the rad is higher then the rest of the engine .. you run the van for about 15 min , then loosen the bleeder valves to allow any air to be removed on both bleeders , even squeeze the hose coming out of the engine to make sure there is no air locked in there , then close valves ..
the good thing with this ez funnel is that you can now drop this stick like drain plug into the funnel so you dont make a mess , then thats pretty much it !! allow van to cool , remove ez funnel and put rad cap back on !! works great for me
