Coolant Leak No obvious source but Coolant visible
Drarkan
So I have a coolant leak in my 95' Pontiac Sunfire 2.2L in a few spots, It is visible on the engine block by the oil dip stick, on the transmission, and on the underside of the engine by the right front wheel. I plan on buying a new coolant tank reservoir and new lines just to be sure, but I wanted to throw this out there to see if its coming from somewhere else. I did notice its also in that little silver plate by the front side of the engine behind the oil dip stick but I don't know what that location is or what to call it. I have included pictures.
oGCNeC9
clean everything off and pressure test the cooling system
coolant leak
I agree with the first reply. pressure clean everything. If coolant is low. fill it. wait for everything to dry. start the car along with the air conditioning and watch. normally, whichever was the highest point of a visible leak that you referred to is where I would watch the most. everything else is probably runoff from driving the car.
