coolant leak!
  • Thread starter Thread starter Bubbbles2002
B
Bubbbles2002
So I have had a problem with the coolant for quite sometime, we have changed the water pump and it seemed fine for awhile now it seems to be leaking even more. My car has overheated 3 times. I really dont know what else it can be, the radiator seems fine. :*( Please help!
Ashley
did you try checking with a pressure tester?
Checking the radiator? Sorry, im a girl, I dont know much about cars :*(
So have who ever changed the water pump check the car.
if you don't find the coolant on the ground, then it is leaking internal.
check your oil, if it looks like chocolate milk then your intake manifold gasket is leaking.
Cindy
I'm a girl too, but I know cars ;)
