Coolant Leak
Dallas86
Hello I have a 98 Pontiac grand am 3.1. I have a coolant leak coming from the passenger side of my motor. it only happens when the car is running and stops shortly after. I have fallowed the leak and it looks like it is coming out from the top of my belt tensioner pulley. Does anyone have any idea what is causing the leak?
Are you sure it's not the water pump, belt tensioners dont leak.
hello...
Hi I have a problem lately while driving on highway got my engine stop and my steering wheel got stock i was lucky to full over my car and when i tried to start it again it wont start for about 2 times then when i try my 3 times it started again and i drive it along to my work when i check all the fluids engine i recognized that my coolant is empty is there anyone knows that the problem of that is because my coolant is empty?
You have a leak somewhere, pressure test the cooling system.
