I have a 67 Firebird with an engine that was recently rebuilt. On hot days, the car isn't necessarily overheating, but I am noticing coolant gathering between the water pump and the block. I can do a pressure test, but I'm wondering if there is another way. I thought the leaks were coming from the sensors in the manifold (Edelbrock Performer), but it doesn't appear to be that. I am left with the Radiator "in" (which is tight), the junction between the water pump and manifold (which I hope isn't the problem, because removing the manifold isn't fun) or the water pump itself. I have a water overflow bottle that is NOT vented (inlet on bottom) and running a BeCool aluminum radiator. As for timing
I am running 8 degree initial, 34-degree all in by about 2500 Via MSD distributor (this is the best I can do, as I'm using the "Black" weight stop and the heaviest springs). Could it be that the overflow bottle should be vented? Would that release pressure?
