Been puzzled over a 93 Pontiac Sunbird LE with a 2.0 liter.
It all started with overheating and I noticed the radiator fan wasn't kicking in. So I checked the relay and it was fine and clicking properly. So I then hotwired the fan motor and it wasn't working... I replaced it.
The fan still wouldn't kick in. Since I had recently changed the thermostat after replacing the heater core recently I decided to check the thermostat and it is opening properly.
The next step was the temperature sensor. I just replaced it and the fan still doesn't kick in. And worse, now the temperature gauge, which was working fine before, now shoots up to the top as soon as you engage the ignition and the engine is cold.
Does anyone have the answer to this puzzle? I can only hope!
Thanks in advance for any help!
