cylinder heads
Holden08
U.A.E Dubai
Hi G8's
I have CR8 2008 GM 6.0 Ls2 engine with six-speed manual gearbox
I'am to go for some modifications and they're as follows
Longtube headers, xforce exhaust systems, vararam intake system, Fast LSXR 102mm Intake manifold with 92mm throttle body , 3.5" g force aluminum light driveshaft and double plates clutch includes Flywheel disc !
I have alread made my mind with all the parts and their brands but I only have a doubt about the cylinder heads , pls advice what's the best brand or which cylinder heads will give my car good performance ? will I need to replace my stock injectors and ignition spark plug wires ?
have you checked out Edelbrock for the heads?
No I didnt, u think its the best one ...?
I 4got 2 add with my modifications list a custom cams :)
Do some rescerch on an ls engine based site. They will know more about modifications.
Heads are darn good stock.... there is a guy with about what you have and he installed ARF 230 V2 heads --- milled to 65 cc nd some other proting on intake and they jumped from 397 to 504 rwhp.... see GRRRR8 forums and "partick g"
The modifications you are trying to do are brilliant but about the cylinder heads you can check online with www.eBay.com or www.amazon.com i saw cylinder heads for sale few days back for G8 just check whether its still available or not.......
