Dash lights problem
soadown45
Indiana
Hey gang got a quick question here basically have a 2003 Pontiac Montana it ran fine until my fiance hit a deer with it then it busted out the front driver side headlamp and turn signal assembly along with the marker light assembly busted that all up but ever since that happened basically since she opens the door dings like the keys been left in it with the lights on all night. Shut off when key is inserted. real kicker is when we're driving down the road and at night and we can turn the headlamps on with the switch but the dash lights do not light up anybody else ran into this and does it remedy itself after you replace the headlight thanks in advance apreciate it
it is unclear from you post whether the damge to all the lights has been repaired. If you have not you may have a short which is effecting other things and you may have blown fuses.
