2005 bonne. with delayed locking feature. works only part of the time. sometimes the security light will come on immediately when a door is opened and the delay feature can be then used. other times the security light does NOT come on as it should when a door is opened after removing the key, still other times it takes up to several seconds before the light comes on and the delay feature can be used. is there a fix ? so that it will always work correctly?
