diagram
milkyy
08 mont i need a wire diagram for the A/C and rear window defrost both dont work their not comunicating with comp. Installed a band new controller and still the same problem. Any ideas or can someone tell me where i can get a diagram?
have you tried a Hanes or Chilton manual? Have you tried registering at autozone and checked their online manuals? Typically a scan tool would be required to connect to BCM to find the issue.
i have tried but i cant find any manuals, also i had it scaned and the shop cant find why its not comunicating with the comp
they used a scan to that can run diagnostics on the BCM?
Yes and they found that there's no communication between controller and bcm
