Dies when warmed up
JJVeld
got a 99 grand am se 2.4l. it runs fine when it is warming up and all. when i gets to ~200 its ok for 5-10 min. then after that when i slow down (city driving) it will die. it wont even idle. i have to drive it like a manual and pop it into neutral to keep it reved enough to not die. it also seems like the gas pedal gets stiffer, almost like the something in the linkage is sticking. what should i do?
is the check engine light on? have you checked if the IAC and throttle body need cleaning?
no the light is off. i was thinking probably something to do with the throttle body sticking. whats the IAC? how do i go about cleaning the tb?
