Reinstalling the companion flange and not sure what to torque it to since the previous owner had removed it. If it was installed I know how to check the preload but since I received it removed from car not sure what to do now.
Gears & Axles - Pinion nut torque?? Stock 10 bolt? - How tight to I put the pinion I changed the pinion seal and the gear slid out. how tight do I put it back in?
