Loneranger
- Mar 6, 2012
I have a 1979 trans am that has a 1968 Pontiac 400 motor, manual transmission. It seems I have to advance the timing past 14 degrees BTDC for the engine to idle at it's best. That makes starting a little harder. The distributor is an Accel 71102E It's an older distributor that is discontinued. I looked up this distributor and it could be used with the vacuum advance or without the vacuum advance. The vacuum advance is still on the distributor, it's blocked off.
I don't know if I should try and hook up the vacuum advance and see if I can get normal timing (9 degrees BTDC) I don't know if any work was done to the motor. I don't think having the vacuum advance connected would be that much of a difference in timing. From 14 degrees BTDC where it is now with smooth idle without vacuum advance to hooking up the vacuum advance and setting the timing to 9 degrees BTDC. I don't think I would get that much advance timing at idle for the motor to run smooth.
I was thinking about getting the MSD distributor with the dial to control the timing. I guess than I would be able to dial it down to 9 degrees BTDC so the car will start easier.
I hope anyone reading this can understand what I am trying to say.
I would appreciate any replies or workable solutions.
Thank you.
I looked at the distributor today, a day after posting the above. The vacuum line on the distributor isn't blocked off. There is a hose from the vacuum on the distributor that is just hanging there (open vacuum, I haven't started it yet to check it). I think the first thing I need to do is try and get vacuum to the distributor and see how the timing responds.
Still welcoming any input.
Thank you.
