do you know what kind coolant i need to buy for my 2004 pontiac grand am
  • Thread starter Thread starter WhAt?
your owner's maunaul will tell you this. Also, under the hood should be a little tag that will tell you. Make sure you use what it calls for. Some anit-freeze is green, some is pink. Mixing the two will cause it to gel and possibly damage your car's cooling system.
GM has been using dexcool for over ten years. Unless someone changed it to the green coolant, it should be orange. They also sell coolant that is compatible with both green coolant and dexcool. I've used the dual use coolant with no problems.
Factory for that car is Dexcool though. Don't mix non-compatible coolant with dexcool, it will turn to sludge, block coolant passages, mess up the thermostat, destroy the water pump in the long run, and it's a pain in the butt to flush out.
