does 2003 pontiac sunfire need lubed?
  • Thread starter Thread starter michael
M
michael
The owners manual says to lube , pronto lube told me the chassis was sealed. I am unsure what to do.Thanks for any help.
If the owners manual says to lube it, then you should be able to find something that needs grease. Check the steering arms and the control arm bushings. The manual might say where it needs to be lubricated.
Most likely it does not need to be lubed. Many newer GM products are permanently lubed at the factory and sealed. There are no grease fittings to lube.
I own a 2000 Chevrolet Malibu. This car is permanently lubed and sealed from the factory. There are no grease fittings on this car to lube.
Isnt the owners manual more specific as to what to lube? Perhaps it says things like door hinges, locks etc?
