Does a Pontiac Fiero have airbags?
  • Thread starter Thread starter A-Dawg
A
A-Dawg
I want one for my first car, but it must have airbags.
PS. im gonna put a 3800 supercharged v6 in it
Edit: Definitely NO on the airbag question, no model of Fiero was EVER produced with an airbag.
Many people have put Supercharged 3.8's in their Fiero. The 3.8 mates up to the stock transmission making it a relatively easy swap as far as custom swaps go. The only clearance issues are if you don't get the Grand Prix GTP motor you have to get some of brackets off of one, and if you don't buy the low mount engine and tranny mounts you have to do some minor cutting to the underside of the decklid. There are also lots of vendors out there that can provide you with mounts, programmed ECM's, plug and play wiring harnesses, and just about anything else you would need for the swap. Best of luck with your swap, be sure to share pics and info as it progresses.
