Door Jamb Rust Issues - looking for Advice.
j5ball
Member
See pics. This is the rust on each door jamb of a 1968 Pontiac Lemans 350. Should I repair the rust areas or should I find entire door jamb replacements. I am being told the issues with the rust in these areas are known issues with 1968 Pontiac Lemans. Thoughts and advice. Thanks . . . . JIMB
If you are fixing it yourself it depends on your skills. For repair only and you know how to work with bondo that would be one option. If you also know how to weld, replacement, would be the better option.
