Which fuse box? Just looked through an online copy of owners manual and didn't see that description. Have you looked in your owners manual
Did you look in the owner's manual?The fuse box located in the engine bay on drivers side.
Compare that to the owners manualMaxi fuse # 5. This is on the inside of fuse box cover in engine bay.
Great thank you.BEC stands for body electrical center. It should feed other fuses. Did you check the others using a multimeter?
