Hello All,
Anyway I am looking for the socket size of the front drive hub nut if anyone can help me out. I may also need the rear as I have not taken the tire off to see how the rotor is mounted.
I am so frustrated with Pontiac right now. What moron decides to make you remove the drive shaft nut to get at the brake rotor. What was wrong with the old design like on my 03 Grand AM where the robot just slides off the wheel studs.
Also the torque value for the caliper bolts if someone has it.
Thanks
Thanks
