1980Esprit
Alright, first thing to start it off.
We own 1980 Trans am as I am sure most of you know by now, and that we are putting in a 406.
Motor consists of .30 block, .10 mains/rods, Eagle H-beams, KB hyper flat top (6CC valve reliefs), Moly rings, stock crank, clevite bearings, melling oil pump, fel pro gaskets, edelbrock performer RPM, rebuilt Q-jet carb, rebuilt pontiac 350 heads, comp cam 262 XE, true dual roller timing chain, mechanical carter pump, heddman LT ceramic coated headers, new valve springs-retainers-keepers to use with new cam, hardened push rods, comp magnum roller tip rockers, ARP head bolts.
We think it will be right around 350-375 HP, 450 TRQ
Car is expected to reach peak torque at 2K, peak HP at around 4.5K-5K
*TH350*
-What torque converter stall/brand to use?
-What rear gears would be best? Has 3.08 LS right now.
-How much for a shop to build motor to specs to handle power?
-How much for me to buy a rebuild kit/shift kit and get it done myself? I would get it done at school because I currently have a transmission class, and the teacher has years of experience.
-What would I need to do with the rear end to handle the extra power from stock?
-Any suspension mods required?
-What gauges would you install in the vehicle to make sure everything is good? (ie: Transmission temp, oil temperature, fuel/air ratio.. etc.. ?)
Thanks for now, Rylen.
*TH350*
