I have a 2007 Torrent with a bad ECM. I bought a recycled on with the same part number. It did not work. I researched the issue and found two answers. First, it needs to be programmed to your VIN or VATS (Vehicle Anti Theft System) will lock you out. Second, if the part numbers match, it will work so the module must be bad. I can get it programmed for $110 but I will only get the purchase price back if it's bad. Does anyone know what to expect from an ECM pulled from a wreck? Should it work if part numbers match? What problems can I expect to encounter?
Thanks,
Tom
Thanks,
Tom
