My 2004 Montana has had a code in for the EGR valve for many years now. Of course, the engineers put it in a place that is next to impossible to access. I started to do the job several times, but got beat every time. After MUCH grief and anxiety I finally managed to get all the bolts off of the EGR valve so I can change it out. I was ecstatic, even though I doubt I will ever be able to get them back in.
I have a new hurdle now. The exhaust tube is stuck in the EGR valve really well. I have tried prying, twisting (carefully), and cussing, but it won't budge. I tried spraying it with liquid wrench penetrant and later brake cleaner, followed by a good soaking with liquid wrench penetrant again. I plan on letting it sit for a couple of days like that and then try it again. I did consider disconnecting the other end of the tube from the exhaust, but that looks at least as difficult and fruitless.
Does anyone out there have a good suggestion on how to separate these two buggers, other than pulling the engine, or using heat (too many things that can melt)??
Desperate
Desperate
