msmart86_2000
- Feb 21, 2010
Vehicle is an '84 Fiero. Does have power locks and windows. Problem started a few months back when the dash lights no longer worked. Replaced the fuse, it kept popping. Took the cluster out, but I couldn't seem to find any shorts. Now, if the thing sits for one night, the battery is dead. I tried to charge it and run it for a bit, then turn it off and use my multi-meter on the back-side of the fuses to find the culprit. No luck, all read 0.0. I have no cluse where else the issue might be coming from. The dash lights still pop fuses after a day or two, but the battery will drain with that fuse blown, so I'm thinking this is two different problems. Any "common" things to look for?? thanks for any and all help!!
Matt
Matt
