drkickback
- Sep 11, 2012
Could someone direct me to the engine cooling fan control circuit schematic for a 1994 Trans Am?
The 3 fan relays were 84 ohms each across the coil, but did not check for control voltage at the socket yet.
I did not see a fuse, maybe this is a fuseable link?
I have not checked for voltage at the fan connector yet.
I was hoping to get a hold of the control schematic to take a logical approach.
Does anyone knows of problem areas with this year trans am?
Will keep you advised as I proceed!
Thank you in advance for any assist on this problem.
