P
poncho
. The question I have and I’m sure the most common is, “How do I verify the engine # matches the car (1971 Pontiac Lemans Sport). I know the VIN codes on the dash. To the left of the water pump on the front of the block there is a number:
C? 231332 YP – I couldn’t find a YP for 1971 in your chart. I did see a YP for 68’ which corresponded to a 350-320 HP.
Was a YP made in 1971? Also should I be looking behind cylinder #8 for something else?
Once I determine the engine id how do I verify it against a identification number on the body?
My VIN # is: 237371g – 115033 –
Thanks. Poncho
Thanks. Poncho
