As I been tearing down the 81 TA, I now have the front clip off I am now getting all the clutter off the engine(emission stuff), AC, alternator and so on, I now can see the plugs in the 305 engine, I pulled the #4 and plug was clean then pulled the #2 and water came out and the plug is fouled up with rust.
I pulled the rest and found 2 more with rust, not as bad as the #2plug.
I then pulled the pan drain and about a gallon of clear water came out then the oil came out.
What does this mean for this numbers matching TA?
Is the 305 toast?
I should be pulling the heads to see the real damage and how bad?
Is the 305 toast?
