The thing to be worried about is the oil pressure, with the amount of sludge you have in this engine, I would recommend a new factory oil sending unit. and a secondary aftermarket gauge to keep a eye on.
The oil pan and pick up tube is bound to be loaded with debris and will starve the engine of oil.
You may want to consider taking the engine out and apart sending it off to a machine shop to basically be cleaned and resealed. rebuilt if necessary.
eventually with enough new clean oil in your engine the now loose debris will clog up your oil pick up tube trashing your engine if it isn't already trashed.
If you do not want to do this you could add a bypass oil filter like found at Amsoil or other aftermarket companies. However I personally think unless some major work is done the engine is running on borrowed time.
https://www.amsoil.com/shop/by-prod...versal-single-remote-bypass-system/?zo=392704
A remote mount dual filter system will do the same thing the added filters may help some yet any debris in the oil pan that is too large to pass through the screen in the pick up will just clog up the pick up starving the engine of oil. I am not sure you have room under the hood for bypass filters.
In the old days where engine sludge was common, we would remove all the engine covers, valve cover timing cover oil pan. oil pick up tube and clean everything.
We would then use a shop vac and a screw driver wire brushes etc to vacuum out all the debris we could get to. along with this we used compressed air to blow out the nooks and crannies that the shop vac wasn't powerful enough suck out.
We also replaced the push rods and lifters, PCV valve and hose. Back then sometimes we also had to rebuild the carburetor to clear the vacuum ports
and on occasion clean the nipples and ports on the intake manifold.
Once we were confident that we had the majority of the sludge out out we would run the engine with fresh oil and filter for 30 minutes keeping a close eye on the oil pressure. then dump the oil and filter, through a screen to see how much debris was still present in the oil.
We repeated this process until no debris was noticeable in the screen we filtered the oil through.
We asked the the customer to return in 500 mile intervals for oil changes until the engine oil appeared normal.
It is also important to make sure the engine is running at peak performance and running long enough.
If the same condition that created the sludge exist it will return. meaning a rich running engine, a cold running engine ( t-stat stuck open ) short run times. ETC
A engine doesn't have to suffer infrequent oil changes to form sludge.
However it is clear from your original post that the oil changes were neglected on your engine.
Good luck with whatever you do.
