engine parts
1980Esprit
Age
28
Virden, Manitoba, Canada
Will the starter motor, timing chain, and water pump from a 80 301 fit on a 400? I am pretty sure they do but wanted to make sure they had. Also wondering if someone could give me a link to where I can get a gasket for the timing cover that has part of the water pump housing in it like the one I will show in the link. I have gasket for the pump but need one between engine block and timing cover. http://www.summitracing.com/parts/aaf-all90019/overview/make/pontiac
Also need to find a seal for the timing cover that goes over top of the end of the crankshaft. Its kind of like a wheel bearing seal in looks.
you should be able to find all the parts in the firebird catalogue which can be downloaded from www.amesperf.com . The parts you mentioned can not go from a 301 to a 400.
