Got the high rpm problem solved. Thanks all of you that helped. Now I have an engine surge will driving or setting still. The engine will surge like it is getting an extra shot of gas. Any suggestions??
If it's a cone shaped even spray it is fine. But if it's uneven or you see it dripping it's either a dirty injector or low fuel pressure.
You can clean out the throttle body with throttle body spray and some injector clean in the tank. A dirty fuel filter can also cause low fuel pressure. When was the last time it was changed? Finally the fuel pump itself can be getting weak. There is a shrader valve to check fuel pressure it should be between 9 and 12 psi. If it's lower check fuel filter and pump. If it's normal check injector.
