engine swap problem
chuck norris
kansas city
i have a 97 sunfire with a 2.2 in it and im putting a 2.2 out of a 95 cavalier in it.
the 95 2.2 does not have a camshaft position sensor on it or a spot on the block for it is there any way around this problem?
you need everything from the 95, ecm, harness, sensors
i herd you could use the harness ecm and gage cluster but i thought that the pass lock from the obII would not let it run.
do you know is it just the harness under the hood?
