Engine Torque Strut Mount removal
coalminer78
Lincoln, IL
Can't find all the bolts. Found one on top by the valve cover bolt. One straight down from water pump neck. Can't find the others. Only thing I find is going thru the compressor. Didn't know if maybe those are used to hold both on. All I have left is the mount, exhaust manifold and heat shield and the front heads ready to come off!! Thanks
Solved.....if anyone else that may need the information you have to drop the a/c compressor down than the mount comes right. So the two bolts in the first post than drop the a/c compressor. Atleast on 2000 model year.
thanks for the update
