Melhoffman
- Feb 11, 2013
Alright here are the codes that I have currently on my 2000 Grand Am SE with the 3.4L V6: P0122 (Throttle/ Pedal Position Sensor/ Switch A Circuit Low Input), P0305 (Cylinder 5 Misfire Detected), P0405 (Exhaust Gas Recirculation Sensor "A" Circuit Low), P0442 (Evaporative Emission Control System Leak Detected (small leak)), and there was another code that was pending when i parked it. It said that the cam position sensor was low circuit or that it was off, i dont remember what it said. This last July i bought the car and it had a blown head gasket and i fixed that and it was fine up until the end of last month. These codes were there for awhile but it wasnt running bad so i left it alone. One day into work it started running horribly, i.e. going up a small hill at 50mph it had to down shift and rev up to 4000 just to not lose any speed, i generally go up that hill at that speed doing 1700 rpm. It starts fine but while running it sounds like it back fires and it idles high as well. It will idle at 1100 and when it sounds like it back fires the engine almost dies. It made a knocking noise for awhile (like a month, coming and going) before it gave out on the way to work. Hopefully this is enough information to solve my problem.
Thanks
Chris
Thanks
Chris
