exhaust manifold
hdbob5454
Member
just bought a 70 lemans with the 350 passenger side exhaust leaks was told its the donut , it is leaking from where it bolts to head wondering if its cracked seems it from manifold more than gasket if it is bad anyone have a passenger side manifold? got to look at it better
Assuming you have checked for loose bolts, remove it and check for cracks or warped. Also could try a header gasket if not cracked.
I pulled it off looks ok going with the header gasket ordered it online just have to wait now
I cleaned it up and checked with a straight edge looked good I put on a header gasket instead of the thin metal one and its fine.
