cagiva9
My wife's Torrent overheated the other day and ended up blowing out a freeze plug. The freeze plug is located underneath the serpentine belt assembly that's mounted on the alternator bracket. I ordered and received the parts then got to work..the problem is that the freeze plugs I received, the same size plug called out by every parts catalog I can find, is the wrong damn size
. I can't speak for all the plugs on the engine but this particular plug seems to be a 1 inch (25.4mm) certainly not the 34.33mm I received and everyone tells me is the ONLY size the Torrent takes.
