Failure to accelerate
DanGP19
El problema que tengo es que mi vehículo Torrent 2009, al conducir, el tacómetro deja de funcionar y el vehículo no acelera pero no se apaga, simplemente no avanza, no genera ningún sonido.
Please translate
The problem I have is that my 2009 Torrent vehicle, when driving, the tachometer stops working and the vehicle does not accelerate but does not turn off, it simply does not move forward, it does not generate any sound.
Do you have a check engine light on?
That's right, because it doesn't have a catalyst.
It's been 9 years without the catalytic converter
How do you know new codes haven't appeared? You need to scan it to determine the current codes.
