fan problems on 1994 pontiac sunbird?
  • Thread starter Thread starter John A
J
John A
When I turn on the a/c the fan blows fine for a few seconds and then stops, because it blows the fuse. If I replace the fuse and try again the fuse blows again. What might be casuing this? Thanks
Could be an electrical problem. A ground could be loose or touching somewhere. You should have it checked out by a mechanic.
if the fan motor is bad it will cause this.always use the right fuse to big and the car will burn. that being said, unhook the battery and check to c if the fan feels atall loose.that is the shaft that goes into the fan motor.if the berring is loose it is bad and that will cause the motor to work harder, pull more amps and blow the fuse.
