fiero clutch
wclark52
Indianapolis, IN
I need help bad my 88 fiero shifts into gear fine but the clutch wont engage at a low rpm if i raise my rpm up to about 4000 it dumps all at once and takes off like a rocket no slipping but makes it tough taking off at stop lights if u can help i would really appericate it
what happens when you engage the clutch at a low RPM, does it stall or it slips?
with low rpm nothing happens its like its not in any gear u can push it backwards no change what so ever
Throw out bearing is worn in the trans. It is sticking to the lip on the shaft and when you raise the RPM's the vibration lossens it.
