Littlebabycar
- Aug 30, 2012
Ok, So the oil light/coolant light is on. I just did a coolant fluid change and oil change not too long ago and both are full. I was told it could be the oil pressure sensor. Only thing is, I don't know where that is. Could someone point it out for me?
Another thing, it has the 2.5 4cyl and it runs rough, like shake the whole car rough, but once you step on the gas it seems to be fine. I did a tune up (plugs wires, cap, rotor) and that didnt help. New fuel pump and filter as well. It just sounds like its running on 2 cylinders on idle and idles at 1200 rpm and will stall out sometimes when put into gear.
One more thing the transmission wont shift (its an automatic) unless I take my foot off the gas, I changed the fluid in it too.
Any help is GREATLY appreciated
