Can anybody tell me the thread diameter and pitch on the V5 compressor clutch
pulling tool? Even if I knew the part number it would be December before I would receive one from the states whereas I could make one on the lathe in an hour and double end it to pull the water pump pulley as well. I should then be able to finish the stripdown and order the necessary parts to be here early December otherwise it will run into christmas Thanks steve
