filling with gas
redneckfromnb
I got an 06 montana and its almost impossible to fill with gas as thepump always kicks out.then you have to squeeze handle very lightly to keep it going. Anyone se have this problem?
you have an issue with the vent for the evaporative control system. Do you have a check engine light on?
so have it scanned at autozone and see if it is related to the evap system
check for a blown fuse, probably the cigarette lighter circuit
well you need to get that fixed to determine if the light is on because of the Evap system
