Fog lamps
trailboy
Anyone know which fuse controls the fog lamps on an 03 Montana?
It is located in the fuse panel on the passenger side,right side of the dash next to the door,actually have to open the pass door to see the cover,once the cover is opened it is labeled as "RR FOG LP" 10 amp .On my 03 there is 6 rows of fuses/circuit breakers the fog fuse is the 3 row 2nd slot down (1 st slot in my 03 is empty ). Good luck
Thanks for you help, I will give that a try today.
I got my fog lamps working, 1 of them had a blown bulb and the other wasn't plugged in.
Now I might try to find some brighter bulbs so they will actually do some good.
Thanks
