Front end noise won't stop
billyhowell147
Western Arkansas
Hi. I'm Billy. I am having some issues. I replaced both front hub bearings. I used junk yard ones. I replaced both cv joints. One brand new and one refurbed, both from autozone. I still get the ?knocking?grinding? I know the bad hub bearing sound this is different. Almost hollow sounding. Gets worse when I go to the right. Could it be the swaybar bushings?
A bad rubber bushing should be pretty obvious. The noise you are describing is usually associated with wheel bearings or cv joints. Using junk yard bearings may be the issue.
