I just replaced my front pads and rotors. The inside pad had worn out, but the outer had not even gotten 1/4 of the way to it's wear and no where close to the squeak tab. So, I mounted the pads with the tab on the inside. Will the wear indicator still make noise or does it depend on which way the rotation goes against the tab?
This is how it's set now...
...the rotation going with the tab.
...or does it need to go against the tab to make noise?
