...need Help? Any suggestions on what I can do to fix the problem? How can I check to see what part of the fuel system is causing the problem? Is it easy to fix?
usually it is the senser inside of your gas tank which is the one sends the singnal to your dashboard.
you have to drain you gas tank then disaseembly the sending unit and see if that is the part that is causing the problem.
Most likely a sending unit and it is in the fuel tank.Unless you know what you are doing i would not mess with it.....IT IS NOT SAFE..You could cause a spark and boom,,end of game.
