Fuel Pressure on a 92 Pontiac Grand Am
SalvadorCorona
Grants Pass, OR
I just insatlled a new fuel pump however, I have to turn the key on/off several times to buil-up pressure otherwise the engine do not run.
Right after the fuel line is full the engine runs smooth and perfect however, when I turn off the engine and later on restarted, do not run smooth until I do again over and over the fuel pressure trick.
So, is out there some one with an answer to why the system looses the pressure?
Thank you for your diligent response.
In regards to the injectors I rule that out however, it make more sense that the NEW fuel pump may be defective considering that I have to drop the tank twice because I installed a NEW pump that failed right away after I re-installed the tank.
Well... I removed that NEW fuel pump and got another freshsly NEW and re-installed just to have the results that I am looking to fix now and that, it is that I loose the pressure overtime.
Regards,
Salvador Corona
