I changed my fuel pump, pretty sure I used the the new o-ring, afterword my car was throwing a evap code. After refueling one time, I noticed fuel leaking from the front of the tank, away from the lines and hoses. In looking at it now, the o-ring seems fine, the pump seems to be fitting ok, but when I tilt the tank gas leaks out from around the fuel pump.
My tank has the lock ring that has the two holes at the end and you have to squeeze together to get off. I wondering if it's my o-ring or maybe need a better lock ring.
