Hello everyone. 1999 Sunfire. Drove it home last night no problems. Won't start this morning. but will crank all day long. I added several gallons of gas to ensure I wasn't out, tried to jump the car in case it was a battery issue, and checked all fuses/relays. I do not hear the fuel pump kicking on when I put the key in the ignition, so I suspect that is my real problem. I have a voltmeter but I'm a little out of my area here and perhaps my search queries aren't very good.
Before I go and buy a pump to put in, I want to verify I am getting voltage to the pump itself. There are three harnesses plugged in near that area and I'm not sure which one it is. I'm also not sure exactly how to check for voltage here.
Is it possible that a clogged fuel filter would cause a no start condition?
Any help would be appreciated, even if it just to point me to a post that I was unable to find on my own. Thank you.
