For many months my 2004 Montana (extended) has had a fuel gauge problem. The gauge always indicates either completely full or completely empty. Never anything in-between. It also has nothing to do with actual level in the tank; it doesn't care. Since I also had ABS issues, I suspected connector C305 and replaced it, even though it looked good to me, since both ABS and fuel system wiring go through it. That did nothing for either one and eventually I fixed the ABS by replacing the EBCM. I was/am getting a P0463 DTC [FUEL LEVEL SENSOR A HIGH INPUT], so all things considered it seemed to be the sending unit. Well, I dropped the tank and replaced the sending unit this morning with GM part# SK1127. The wipers on the old unit were half gone. I got it all back together and voila! ...same old problem. The gauge pegged out high for a few seconds and then failed low. Thinking it was just re-zeroing I filled the tank half-way. The gauge registered completely full. I then proceeded to put in the remaining 14 gallons. Still pegs high or low.
Could it be the PCM? Any ideas out there??
PS. I ran a check on the crappy old sending unit after the fact and it is in working condition.
