Gasket Job
fatback1980
Hi Everyone,
I am going to tackle a 2003 Montana Head/Intake and valve cover gasket replacement (Losing Coolant and exhaust bubbles in the coolant). While I am in there, I plan on replacing the plugs, wires, thermostat and upper o2 sensor. Is there anything else I should consider replacing while doing this? Also, if you have done this job, give me any advice you may have.
Thanks!
personally on an engine that is 10+ years old, I would send the heads out to a machine shop to check the condition of the valves, seats, and flatness of the heads. Intake, if it's really built up a dremel.
